Hi, peeps, just installed a small ring in a farm barn, R1+R2 =0.02ohms, Zs at mid point = 0.64ohms. when i measured Ze, i got 0.67ohms. now, unable to dis. main earth as it's a sub-main, fed in SWA using armour as the earth. with parallel paths, i would have expected the error to be on the lower side rather than the upper. as readings are within limits, should i investigate further or leave well alone?
