Okay, that's fine then....
Well i suggest you re-gland up the wire armouring on both ends of this SWA cable to ensure grip and tightness and then install earthing nut's or banjo's to each gland with fly leads to earth bars. By the way, what size is this SWA cable we are talking about??
It's only a 2 core 4mm2. And I have done what you have said and still received the same readings, no change whatsoever. So this process identifies a break in the armourings I would say?
The company I work for received a contract of about 30 of these installations, I can see this problem arising on every site.
