Zs fault | Page 2 | on ElectriciansForums
Discuss Zs fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
its what they teach you these days and reason i said that is because we were talking about the exact subject on monday. not always an option for new circuit or breaker device to be reduced, thats all folks!!!!!!!!!!!!!!!
had a similar problem to be solved in the 2391 practical.
Zs value was too high for ADS.
Assuming the system is TN-C-S
Number of solutions:
Check R1 +R2 equals what you would expect using the resistances/m as shown in OSG page 166. Could indicate poor connections
Check the MCB type as it could be a C type where it may be possible to have a B type depending on what the load type is. B types have a higher max Zs value compared to C's
Could reduce the length of the circuit
Could use cables for the circuit having a larger csa
and if all else fails there is always the fast track course 7 weeks learning how to lie through your teeth, become a .......... politician, lawyer, estate agent, salesman, banker, care home manager, any manager, sure there's more.......
Reply to Zs fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Agreed, loss of N further down the network can give wildly changeable voltages If it is tied to earth, then that will go up and down too.
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
