Zs on tt | Page 2 | on ElectriciansForums
  • Thread starter james king
  • Start date
  • Replies 18
  • Views 2K
Discuss Zs on tt in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If people are having trouble understanding this magic '1667 ohms' number.. it is obtained from:
50V / 30mA = 50 / 0.03 = 1666.6666666666666666666666667, rounded up to 1667 ohms.
was about to say as widdler max. touch voltage 50 so 50/0.03mA = 1666 recuring rounded to 1667, but OSG says anything over 200 ohms should be considered unreliable due to soil drying out ect.
TT probs with B.Gas 'engineers' having plug in Go/noGo testers for supply to boilers having fail setting of a couple of ohms, trouble is they are always taught on TNS systems and don't understand TT.
No, the On-Site Guide is referring to the RA value (the Ze if you like) NOT Zs values!
Reply to Zs on tt in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
