Zs reading with main earth disconnected | on ElectriciansForums
Discuss Zs reading with main earth disconnected in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Morning, just checking a lighting circuit on a house, I have the main earth disconnected and still get a zs reading of 2.2 ohms. No evidence of an earth spike and bonding goes direct to henley block.
Any suggestions why this could happen??
I don't understand either. And why would you expect the CPC to be insulated from earth throughout the installation? It could take any value from infinity to zero without indicating anything abnormal. I can see why it might be useful to know for forensic analysis but not for normal testing.
So to answer why I had the circuit energised with the main earthing disconnected..
The lighting circuit connected in board had no CPC so I checked the Zs at a ceiling rose.
I had a reading of 2.2 ohms so I then tried to find out where the earth was coming from.
I disconnected all the CPC's from the other circuit in the board, checked Zs again and still had 2.2 ohms.
Just try and eliminate things and to see if I was picking up earth from elsewhere I then disconnected the main earth and still had a reading of 2.2 ohms.
Reply to Zs reading with main earth disconnected in the UK Electrical Forum area at ElectriciansForums.net
Just re-read the OP's post and it is an existing 5C SWA so presumably a 3P supply. For 40A and 150m you are seeing 6.6V drop or 1.65% of 400V 3P...
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
