Discuss Shower pump power work/alterations in the DIY Electrical Advice area at ElectriciansForums.net
Afternoon to all!
I have to replace my current shower pump as it's on the way out, it's loud at the best of times so I have taken the opportunity to replace with a quieter unit but my problem is it's a different make and as a result the power supply is also different, the new pump comes with a mains plug and the old or current pump is wired directly from the pump to the 5a spur.
So my question is can I just replace/rewire the spur faceplate for a standard switch socket?
Many thanks, sparky gods
Old pump: Boss 10036501
New Pump: Salamander CTForce 15
You could do, but you would need to check the wiring out to confirm it's OK, you easist way is to cut the plug top off and connect your new pump directly into the spur, of course this may invalidate the warranty of the pump.
Thanks Pete, it did cross my mind initially but I binned the idea after reading the manual online and it said it huge red letters not to do it and it would as you say, warranty void.
So warranty aspect aside it's perfectly OK to wire into the spur with the pump having its own built in fuse too?
Providing the fused spur has the correct size fuse yes it's OK what size fuse is in the plug top? transfer that to the fused spur and all OK, do the instructions mention what size fuse should be used? when you say it's own buit in fuse, are you referring to the plugtop fuse?
Yeah, that's correct, at the minute the spur has a 5A fuse in it for the current pump, the new pump data sheet/instructions 3A.
Understood, the 3A plug fuse would go into the spur in place of the current 5A.
I guess it's just a question if I want to take my chances and void the warranty now! thanks
I'm going out on limb here, but if the OP is competent enough to remove an FCU to attach the flex from the pump, could ne be competent enough to replace the FCU faceplate, with a single switched socket and not worry about invalidating the pump warranty?
The OP would need some knowledge of testing and have some experience in installation methods, to ensure the existing spur has been wired correctly and conforms to BS 7671, he has no qualifications, I only suggested the connection unit option as it would be the easiest and most cost effective method of connecting the pump, other than the warranty issue, but yes your point is very valid.
Personally I think if challenged the 'you cut the plug off so your warranty is void' argument wouldn't hold much weight. It annoys me that manufacturers put the frighteners on people in that way because cutting the plug off isn't changing any parts of the pump that are likely to fail under normal use, it's just connecting it to the fixed wiring installation.
Rant over :)
trouble with these manufacturers mouldy plugs is that you can't see if it's wired correctly.
Rant over :)
The problem in this case, is it explicitly states not to do that. So when it packs up 1 day before the warranty expires, and it takes back to the retailer, he'll get the 'Ohhh, you've cut the plug off. What a shame' routine. :(
Reply to Shower pump power work/alterations in the DIY Electrical Advice area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
I'm sure this has been asked before, but I just want to confirm: Currently I have a spur leaving a socket in the bedroom, into a 13A Switched...
A recent EICR turned up a fault: an RCD fused spur was feeding a socket and a shower pump, and neither socket or pump had continuity on the CPC...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
