Discuss Understanding/fault finding jacuzzi pumps in the UK Electrical Forum area at ElectriciansForums.net
Hi All
Been on a job today and while there was asked to look at jacuzzi which hasn't been working for a good while. Wondering if anyone got much experience of these mine is completely zilch. I proved 230v coming in to motor pump but beyond there I haven't got a clue on the mechanisms to make them work or testing process to eliminate what might be faulty. On the bath itself it has a push button which has tube going down to motor which I think this air pressure activates motor? There is also a power dial. Both of these look like they need replacing to me. If check photos out there is also a white thing that looks like transformer but don't think it is what is the actual purpose of this? Any sort of heads up be appreciated as hoping might not have to replace the entire pump
What is wrong with it? You have not said!
I presume it is doing nothing at all, but some idea of what is expected versus what you are seeing might help! Has it a heater? Just the pump? Any indicator lights to show power/running/etc?
the round white thing is a capacitor. motor needs that either to start.run,or both.
I suspect it's a waste of time getting involved with them.
If you did find the fault, which should be reasonably easy for the more experienced, it could prove difficult to get spares as there have probably thousands of different models over the years from all over the World.
If it was your own it would be worth doing, but although there are plenty of online companies selling spares, it's the time to source and wait and revisit that'll be the problem
Hi Pc. No, no indicator lights to show it is or isn't working. Apart from proving supply good into pump not really sure what next port of call is to check. Think could potentially disconnect the capacitor but can this be tested to check working ok? Am I right in presuming it's the actual air pressure from push button that closes switch within motor to operate it? Maybe if can check or find issue with anything else this might be first thing to replace
[automerge]1591043494[/automerge]
Thanks Telectrix. How would I best test these to prove functionality
[automerge]1591043971[/automerge]
Do you think changing the whole pump/unit might be better option then Snowhead? Finding something pretty like for like shouldn't be to difficult should it? And reconnection and plumbing in shouldn't be to tricky?
you can test a cap. witha meter that has capacitance range, but that is only a giude. it could read OK but break down when a higher voltage is applied. only sure way is to try a replacement.
i'd start by checking if the air pressure triggered the switch.
If it were a capacitor fault you would hear buzzing from the motor and/or the MCB would trip on over current, etc.
Doing nothing at all strongly suggests a fault in the control of the system (safety switch tripped, not seeing water present, etc), or just maybe something as simple as a fuse to the control stuff having blown. I have never poked inside one of them to have any other suggestions I'm afraid :(
Cheers Tel. Am back there for few other jobs will try to pick up capacitor to swap out with. The push button old and not working but suppose just blowing down the tube should hopefully be able to test if switch is triggering ?
Reply to Understanding/fault finding jacuzzi pumps in the UK Electrical Forum area at ElectriciansForums.net
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
Hi, I hope that someone here might be able to put my mind at rest. I have an engineering mind and a reasonable understanding of electical work...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
