Discuss Lighting circuit advice please!!! in the UK Electrical Forum area at ElectriciansForums.net
Hello all.
So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so forgive the ignorance.
Doing a bit of dead testing on a lighting circuit downstairs. Came across this at a light fitting.
Appears that the colours are cross polarity which I can deal with, But then the arrangement of these conductors feeding this fitting makes no sense to me at all. Any, advice welcome!!
In addition, at another light fitting on the same circuit I got an Rn of 0.58 back to the board, no R1, and 42 ohms line to neutral at the fitting. Haven't got clue. Help please 😁 pic attached
Thanks a lot
ý
If you search online for “loop in” or “3 plate” wiring, you should see this.
Well done for doing this as “dead” testing…. Many novices or diy think, switch off, light is off…. But they don’t realise the bunch of reds are still live.
42ohms live to neutral is most definitely a lamp in circuit.
Take care of you’re zapping 500v with an MFT across L and N…. It will damage anything electronic such as LED lamps, dimmer switches, smoke detectors, extract fans…..
Thanks LS! I am familiar with 3 plate roses though usually end of line, never seen a mid run 3 plate in choc blocks so just unfamiliar territory but drew it out and now I feel a bit stupid for not seeing it! I'm aware of the permanent lines in lighting circuits so always isolate.
Would you mind expanding on the 42ohms reading LN? It wasn't from an IR test BTW. I know loads in circuit can ruin IR testing. It was a continuity test at a fitting so makes no sense to me how this would be possible.
Thanks so much for the help
Yes. How are you testing, using a long lead?
Yeah using a wander lead with the conductor out of the breaker at the board end. The circuit was functional so perhaps I just missed an open switch yeah. I'll remember to double check in future thank you.
But the reason for moving on was the bizzare 42ohms reading on the continuity setting between L and N threw me. Id already seem polarity colour swaps elsewhere so started to just test combinations and that didn't make any sense to me.
Thanks for the help
Reply to Lighting circuit advice please!!! in the UK Electrical Forum area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Evening All, Strange one so after a bit of advice. Got called to a customer this evening who had their boiler repaired after the circuit board...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Good afternoon! I've recently wired a lighting system, where one light switch (a motion sensor) turns on two lights, but another motion sensor...
