Discuss Legality of using a lighting circuit to power an observatory? in the DIY Electrical Advice area at ElectriciansForums.net
dgstrange
I have a lighting circuit cable (1mm) powering a telescope (12 volts) in an observatory total draw 84 watts drawn from a transformer. There is a 6 amp fuse in the consumer unit. This was installed in 1998 by a qualified electrician. Is this still legal or should it be upgraded?
Courtesy of a recent change in the regs, it wasn't allowed then, but it is now.
Up until the change, the minimum csa, for anything other than a lighting circuit, was 1.5mm2, but now that's changed to 1.0mm2.
There may be, of course, other things that could do with improvement by now, but this isn't one of them (anymore).
Many thanks, that is very useful to know! Would you by any chance be able to provide a link to those regulations?
Reply to Legality of using a lighting circuit to power an observatory? in the DIY Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi My main feed comes into the garage, feeds into the meter and then out to another box with a 60AMP fuse then into the house...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
