Discuss Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
As per title has anyone got a wiha torque screwdriver?
Yes, I have a Wiha set (torque handle, adjuster, various bits).
One criticism is I find the very small print of the torque setting hard to read, especially in low light.
i'd like to put one to good use in paul m's arse for that wind-up.
don't trust them a s far as i can throw 'em. torque up 25mm tails as per manufacturers settings, then give ' em a wriggle. they'll either come out or you can the give te screws at least a 1/2 turn to secure.
don't trust them as far as i can throw 'em. torque up 25mm tails as per manufacturers settings, then give ' em a wriggle. they'll either come out or you can the give te screws at least a 1/2 turn to secure.
With cable such as 25mm tails, whatever you use to tighten up the connections, leave them a while and often you can tighten them some more, as I guess the strands move/settle. I typically tighten these, and a bit later check/retighten.
Does it get much use, or is it really for arse-covering purposes?
For day to day work I would have to say no , we hardly ever use our ones .
But when it comes to larger supply's and multiple dis board installs , then it is worth the effort of getting it out and setting it up to the correct values .
I know that it sort of defeat's the point in having one and not using it all of the time , but to be honest I have mixed feeling's about relying on these and prefer to trust the experience and ability of the man doing the job , with the use of these as a belt and braces approach on the larger loads .
We use the Wera 1/4 inch hex type in 3 different torque ranges in our workshop. They're in constant use 5 days each week on the panel building benches and they last pretty well. We had 2 fail calibration recently and they were 3-4 years old which is pretty good going for the amount of use they get.
New posts
Reply to Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Hi Chaps I've got a Wiha torque driver but only came with couple of bits (below)... none of which fit 'outgoing side' of Contactum RCBO's...
Well i brought a set because i needed this MOD1 &2 (wouldnt mind but the shops didnt even know what i was talking about) S1&PH !! well ANYway i...
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
10K
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I have had mine about 3 years ( maybe longer ) and have never bothered to have it reset Does anyone or has anyone bothered to have their vde...
