Discuss Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Work issued me one and it's handy to have. It saves you wrenching the mcbs and causing them damage and it also saves fatigue on your hands by needlessly over tightening. The kits really good and easy to setup. Just watch 1mm connection as they might snap due to torque setting.
Learning to tighten a screw properly will save you from damaging MCBs when you tighten them .
And if 1mm snaps due to the amount of torque applied then you are over tightening it
because the torque is the recommended max!!!! torque not what you should be hitting every time.
No they specify what nm each connection should be tightened not there abouts. Why would they specify a number and expect you to just go a little below that. It's a specific number for a reason. Think!
I have read it and I do understand .
If you tighten a terminal to the point where the conductor snaps then you have over tightened it, what is there not to understand?
The brand specifies the nm that each connection should be tightened to. If they specify 2nm and this causes the 1mm to snap it's not your fault it's the brands. Get it?
That is your fault , if you don't have the basic practical skills to tighten a terminal correctly them electrical installation is not the job for you!
Reply to Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Hi Chaps I've got a Wiha torque driver but only came with couple of bits (below)... none of which fit 'outgoing side' of Contactum RCBO's...
Well i brought a set because i needed this MOD1 &2 (wouldnt mind but the shops didnt even know what i was talking about) S1&PH !! well ANYway i...
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
9K
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I have had mine about 3 years ( maybe longer ) and have never bothered to have it reset Does anyone or has anyone bothered to have their vde...
