Discuss Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
to be fair on tri-rated etc we would just use ferrules.I think that termination technique is at least as important as torque.
For example, I have been in the habit of 'untwisting' the strands of some larger cables (tails) when terminating as I reasoned that the strands could then move freely to take up a minimum space in the terminal and be less prone to loosening.
There was a report about this a couple of years ago:
http://www.electricalsafetyfirst.org.uk/mediafile/100015987/Switched-On-24.pdf
See pages 14 and 15.
The original experimental report is here:
http://www.electricalsafetyfirst.org.uk/mediafile/100013801/Meter-Tail-Investigation-Report.pdf
I think that untwisting rather than 'flattening' is what matters. The group of strands will take up the shape of the terminal when tightened.
The technique is probably not of any use for small cables with fine strands in some large direct screw terminals, as the strands will just displace up the sides of the screw.
Never seen any proteus kit so I would not know
Reply to Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
