Not knowing what you have access to over there it's a bit tricky to answer, but I would probably use a Wiska 308 and a PVC conduit adapter that screws into the pre-threaded holes of the box. To try and seal the thread I would probably apply a sealant/adhesive like 'Sticks like shi*' to the threads before screwing the adapter into the box.
Unless the box is going to be submerged, you should always put a drain hole in the bottom/back wall at the bottom as no matter how hard you try there will always be a certain amount of moisture build up in there.
<p>Founded in Hamburg in 1919, WISKA develops and produces innovative products for customers worldwide. </p> <p class="MsoNormal"><o:p></o:p> </p> <p class="MsoNormal">Their cable glands are used around the globe and characterised by flexible applications in diverse areas of industry as well as...
