Search the forum,
Discuss Cooker Hood wiring Installation in the DIY Electrical Advice area at ElectriciansForums.net
Status
Not open for further replies.
Brian G
Hi
I also posted this on the DIY Electrical Advice - Electrical Appliances Forum
My Kitchen has never had a cooker hood installed.
Where the new hood is going to be situated is some distance from any of the outlets in the kitchen ring main.
However there is a cable coming out of the wall near where the hood is going that was originally intended for one of a pair of wall lights that were never installed. the cable ends are terminated into a choc block as is the end of the other cable where the other wall light was going to be on a nearby wall.
Can I attach the cooker cable (which has no supplied plug)to the corresponding terminals in the choc block of the nearby cable, and fit a double pole fused connection unit - protected with a 13amp fuse or a 3amp to the other unused wall light cable?
Hope this makes sense
Brian
See this thread.
Status
Reply to Cooker Hood wiring Installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
I need to install a floodlight for outside now its dark. Its just inside the kitchen wall to connect to the electrics. My simple idea is run a...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
