Search the forum,
Discuss Fitting new Cooker hood in the Electrical Appliances Forum area at ElectriciansForums.net
Brian G
Hi
My Kitchen has never had a cooker hood installed.
Where the new hood is going to be situated is some distance from any of the outlets in the kitchen ring main.
However there is a cable coming out of the wall near where the hood is going that was originally intended for one of a pair of wall lights that were never installed. the cable ends are terminated into a choc block as is the end of the other cable where the other wall light was going to be on a nearby wall.
Can I attach the cooker cable (which has no supplied plug)to the corresponding terminals in the choc block of the nearby cable, and fit a double pole fused connection unit - protected with a 13amp fuse or a 3amp to the other unused wall light cable?
Hope this makes sense
Brian
fit a 3A or a 5A fuse, depending on the hood's requirements. RTFM
Hi Thank you for your response,
From what I understand then will it be OK to use the cables that were originally intended for wall lights and are on the kitchen lighting circuit?
Just to confirm - connect the cooker cable to the choc block connector on the nearby wall light cable.
And fit a double pole fused connection unit onto the other wall light cable on the other wall.
There is nothing in the cooker hood installation requirements that relates to the fuse rating,the only reference is for the power supply 220-240V -50Hz
It has two 3W lamps,and a 210w Motor
The cooker cable did not have a plug fitted
Brian
that wattage is just aboult 1A so will be fine.
Hi,
Thank you so much for your reply
Basically is what I have asked about re using the wall light cables and fitting a switched fused double pole connection unit OK to go ahead with and will I be OK fitting a 3amp fuse to the unit then rather than a 5 amp ?
Many Thanks
Brian
Reply to Fitting new Cooker hood in the Electrical Appliances Forum area at ElectriciansForums.net
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
