Currently reading:
DIY how to wire new circuit breaker to new switch and recessed LED lights?
Discuss DIY how to wire new circuit breaker to new switch and recessed LED lights? in the DIY Electrical Advice area at ElectriciansForums.net
Mannyv777
I recently installed a new 15amp circuit breaker, and wired a 14-2 gauge wire to a brand new dimmer switch. From the dimmer switch I daisy chain wired 6 LED recessed lights. When I turned on the circuit breaker the lights all turned on, but the switch wasn't working. I then changed the switch to a different configuration that uses the 3 wires only, the lights would turn on, but when I'd go to flick it off the breaker would trip., I exchanged different switches and same issue. Install a regular switch no dimmer and same issue. It'll trip my breaker when I'd go to switch it off. What am I doing wrong??
Reply to DIY how to wire new circuit breaker to new switch and recessed LED lights? in the DIY Electrical Advice area at ElectriciansForums.net
