Search the forum,
Discuss EICR ring circuit question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doing an EICR and was looking for some advice, testing the socket circuit, it’s a ring circuit. 3 sockets in the living room area, opened 2 up and they both had one cable at it (great). Opened the 3rd and it had 4, so obviously the other 2 sockets are fed from here. Now I know you are allowed to spur once from a ring, but I’m assuming as that is spurring to 2 different points, it’s a no no? Was wondering what you guys thought
Read and inwardly digest Appendix 15 BS 7671
If there’s been a lot of work in the past, it might be a “figure of 8” ring where it’s been extended, with 2 legs joined in the box and 2 legs joined at the socket… Dicky DIYer comes along and puts them all together,
and the two spurs are off round joint boxes under the floor.
As above, prove the theory first.
4 cables in one terminal as you think it is, (ie, ring and 2 x spurs) isn’t good… would be a hotspot if spurs were heavily loaded…. but if the double socket was 2 singles next to each other, it would be alright.
Reply to EICR ring circuit question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi All, Had a weird one this morning during an EICR. Testing a ring final circuit in a 2 bed flat… kitchen was on a separate ring. With only the...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
