Discuss Failure of emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Gents,
What is your view from this this clause from BS5266?
If you have a lobby with that is part of an escape route that has one fitting, I have never seen an additional fitting being added to satisfy this clause. Even in rooms with two fittings, I have rarely seen both being used as emergency versions??
Dees this not have to be looked at in a practical sense? If you have an intermediate escape route lobby 3/4sqm with one light where the entrance door hasn't even closed by the time you open the exit door, putting another emergency light/ exit light here is excessive.
Also a storage/plant room that is 4/5sqm with one fitting? I have never seen an additional emergency fitting put in these rooms
The requirement is a relatively new inclusion so there will be many installations which do not comply.
Reply to Failure of emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
I own two flats with a small common lobby. Although operable from both flats, the common lobby light appears to be wired to flat A's circuit...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
