Search the forum,
Discuss Heating system is via an air source heat pump. in the DIY Electrical Advice area at ElectriciansForums.net
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment.
The heating firm have ceased trading before the system has been completed and fully commissioned. Ground floor is UFH with 6 zones controlled by Heatmiser UH8 RF, 6 Heatmiser Slimline RF thermostats which connect via WiFi to the UH8 RF, and a circulating pump attached to manifold, and flow and return runs connected to buffer tank. This all works fine. First floor is radiators. and a second pump has been installed on the other side of the buffer tank for this circuit, but has not been connected to the Heatmiser UH8 RF or to a mains supply.
i would like to use a single Slimline RF thermostat to control this second pump for the radiators circuit and would appreciate any help you might be able to offer me so I can pass the information on to my local electrician. On the UH8 RF zones 1-6 are used for the UFH and zones 7 and 8 are unused
Reply to Heating system is via an air source heat pump. in the DIY Electrical Advice area at ElectriciansForums.net
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hello , I’m trying to further my knowledge into UFH/Rad/HW valves heating systems with air source pumps. What is normally needed outside with...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
