Search the forum,
Discuss Mobile Home 3-way light switch to smart switch in the DIY Electrical Advice area at ElectriciansForums.net
kymyost
Hi! We recently moved into a new mobile home and want to install a few smart switches. I know about installing box as these are not self contained like the old switches. My issue is understanding the wires. Below is my setup in the walls. Both switches control the light independently now. I don't really care which switch I replace as the smart switch.
1. Which switch should it go on? The one closest to circuit breaker or the end of libe switch? I'm assuming the one coming from the circuit breaker as that one has a ground wire that is not hooked up currently.
2. And which wires go to which location? I know the white from the panel is load and the black is neutral then can not get my head wrapped around the wires going out to the other switch/lights. Looks like red is the main load carrier so L1 or does it get hooked into the wire nut with load from the panel? Then where does the black and white hook? 🤔 Help a girl out please!
Reply to Mobile Home 3-way light switch to smart switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi everyone. I bought one of those smart switches, specifically the Kasa 3 way kit (HS210 KIT). But when I opened my 3 way dumb switches I see...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
