Discuss New T&E cable... in the UK Electrical Forum area at ElectriciansForums.net
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own.
I also read somewhere that this will soon become the norm and will have to be installed to comply with the regs instead of the regular cable.
Any truth in that?
It would seem odd to think that a new reg would be introduced, mandating a cable only recently introduced by a single manufacturer, shortly after a recent amendment to the current edition of wiring regulations.
Funny thing is…. I was using this in Europe twenty years ago….
The only reason we sleeve the CPC is for identification so as far as I’m concerned this is a pointless exercise except if you happen to be a price job house basher and see it as yet another 5secs off the time of your already shoddy wiring.
(And before anybody cries that it’s about insulation, consider the simple fact of conduit used as cpc).
Furthermore a representative of Doncaster Cables themselves has also stated that it is not rated as insulation, but is merely there as identification as you state.
Where did you read it?
An Aprils fool joke created by Efixx
BS12721:2024 residential cable standard. This standard will ensure safer and more efficient wiring for your home. However, it also means that the trusty BS6004 cable will be phased out and cannot be used for new home construction or rewiring starting in April 2024
Reply to New T&E cable... in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Can someone sanity check my thinking please.... An 80 amp PME service head, tails to meter, 25 sq mm tails into an enclosed fused isolator with...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
