Search the forum,
Discuss Supply Cable Location in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
the electric supply cable to my property is fixed to an external wall and is with touching distance from an open window. Is there a minimum safety distance requirement or is this ok?
Thanks for any advice
Is it an underground cable running up the wall or is it an overhead cable coming from a pole? A picture would help.
It’s an overhead cable coming from a pole.
All looks quite new so should be safe, the joints I think are a type called insulink and are preinsulated crimps so should also be ok.
Supply companies comply with different regs than the IET regs. I don't think the supply company would change anything. If it really bothers you, you could ask for a price to have it undergrounded.
Reply to Supply Cable Location in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
