Discuss Voltage Optimiser Inspection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi
i've been asked to look into an existing voltage optimiser unit, and provide feedback on it whether or not it needs to be replaced. Is there anything i should particularly look out for? Customer also wants the info on size and type i assume this info will be on the VO?
Oh there is a blast from the past, they were used in the main to get correct voltage for fluorescent tubes as with the old wire wound ballast a small over voltage could result in power being used to nearly double.
However with electronic ballasts that problem vanished, and most other items now have switch mode power supplies, so rare to be still required.
There may be some odd times, when they as still required, where voltage is outside the normal permitted range, but today rare.
Reply to Voltage Optimiser Inspection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
Hi. Can somebody please advice what to do next or should I do anything next or just leave that cable as it is? Just bought the house and found a...
R
Hi Guys, looking at doing Initial and Periodic inspecting and testing. Looking between the CandG and EAL Just wondering if I can ask peoples...
Hello, I have a EV charger that is reporting over voltage and is unable to charge. the charger will operate up to 253V The solar inverter reports...
Hi, I was looking at my dishwasher and it has this metal plate with these markings. I am confused about the meaning of "10/16A" - does that...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
