Depending on its size ... ! Large house, single radial, surely not!
It's shocking that the sockets were just labelled sockets and not up or down etc, it's not good, you can tell standards are dropping.
6.0mm2, sorted ;-)
Oi. I done my apprenticeship on new builds!!!!
Insert joke here................
UKsparks
you can put every socket on its own DP RCBO if you decide.
or the whole house on a radial.
its up to you!
I am not a great lover of radial socket circuits, but why not.?
Ye gods! A house wouldn’t need a consumer unit, it would be a full switchboard.
If you feel so inclined, you could do an entire house with an individual radial for each outlet. Burying this little lot in the plaster took some doing. Hiding the board was a nightmare.
The wife wasn’t too happy with it, she divorced me.
BTW, I’ve never doled out so many thanks in a single thread, the thanks are for making me laugh, I needed cheering up ;-)
What do you mean standards dropping. Most houses up to the 1980's only had one ring circuit for the whole house and they are still operating just fine. On an average new three bed I do one RFC for kitchen, one for the rest and/or sometimes seperate bedroom radial, sometimes not, depends really what the situation is. To be honest, additional RFC's is more about having areas split onto separate RCD's to minimise disruption under single circuit fault conditions than it is a loading issue. I still like RFC's but prefer KFC's!
I disagree with that statement, well at least in the area i was brought up. Even my parents house (circa 1950) had upstairs and downstairs ring circuits and dedicated washing boiler outlet and emersion heater switch wired in 7/036. And that was originally a council house, but in those days council houses were built properly and often to a much better standard than Private housing estates.
Am I being thick or are kitchens supposed to be on their own circuit, I'm talking of a brand spanking new house.
Its so that when you get called in to investiagte beacuse 'the house electrics have tripped' they're still able to make you a brew![]()
not if it's been there for 20+ years. then you'd have called him "a forward thinker"Unless some numpty has installed an upfront RCD!
New builds are wired by numpties, low skilled ones.
