Ze Values? HELP
only a bit of banter so far.
Hi,dude, You will have to grow a sense of humour,as you have only had 20% of the 100% normally given,which is,after all,only one seventh....:conehead:
well all i can say is the onsite guide should write it as 0.80, thanks tho that makes alot more sense than the regs
Why should the write it as. 0.80 if they mean 0.8? The numerical value is the same but the implied accuracy is not, 0.80 implies greater accuracy than value than 0.8
Could it be that it was 0.8 exactly, with the zero dropped as it would be irrelevant, to the outcome calcs.
Sorry I'm trying to get my head around this, not disrespecting your post.
The zero is relevant to the outcome of the calculation as it will have an impact on its accuracy.
0.8 x 0.320 = 0.3
0.80 x 0.320 = 0.26
0.800 x 0.320 = 0.256
0.8 is a value anywhere between 0.75 and 0.84 wheras 0.80 is a value between 0.795 and 0.804
0.8 x 0.320 = 0.3
0.80 x 0.320 = 0.26
...Your calculator needs re-calibrating...:icon12:
Yes mate. If the 2nd, 3rd 4th etc decimal place is not required, dont need to use it or it would become 0.800000 or 0.8 X 10 to the power of minus 6 :wink: (level 3 maths, you will see)
^^ that is correct isn't it gents? Been a long time since writing this form of equation and it does not look right?
This is getting too in depth,anyone know if my maths are right,I seem to keep getting e=mc squared
Underpaid,
newtothis,
