Solutions for Surface mount to conduit.
Yes that's just the sort of thing. Its just that I rarely get a single socket they always seem to be doubles.
I did a job like this recently and use a pvc double box over an existing single:
I see you have used pvc fixings over that door.
If a door from a room leads away from a hazard to a place or route of safety it is deemed an escape route and from the picture I suspect it does.
As it has a closer I suspect it is an escape route. But why worry about the wiring with a flat screen TV mounted above the door? I'd worry more about that falling on my head as a fireman..
Would some metal conduit clamps over the plastic above the door be enough to be compliant?
Steel saddles are a solution and easy to retrofit.
You would be pushed to find any door which would not be part of an escape route in a commercial premises.
When ever I read Pat H's threads I always get the feeling we are not being told the whole story.........
What story do you want?
I'm not buzlightyear I'm afaid. Whoever that is.
On more than 1 occasion, in threads, its become clear after numerous replies that you eventually provide additional useful information.....
Your house or an unsuspecting customers?
Sorry if my eventual additional info is useful. (I think not really sure what that is)
read my profile info it tells all there is to tell.
I have posted posts related to my house and others related to customers or just general questions.
Pat H,
davesparks,
