Hi.
I have a radial circuit supplying electricity to the garage (part of the house). It's on a 20amp breaker, uses 2.5mm cable. It currently only supplies a single socket. Before anyone asks, its 100% a radial circuit. 6 months ago I had an electrician install a new consumer unit, and the testing/certificate that followed states this.
There is a single socket on the circuit. Annoyingly, the socket is at the back of the garage and right in the middle of the wall.
What I would like to do is keep this socket. Then... come out of the socket on the left, and put a socket on the left wall, and out of the right and put a socket on the right wall. I cant continue the cable round in a single direction as the garage door and other things are is in the way. Coming off in both directions from this socket it the only option.
Would this be ok? An alternative I had was to come out of the the top of the socket into a junction box (30A), then the two cables come out of this... best described as a T junction.
In case anyone wondered, there will not be any high load appliances used. One will supply the chargers for my tool batteries, the other will be Christmas lights!
Thanks in advance.
F
This thread has drifted way off topic. The OP asked whether he can legally carry out these works, the answer is yes. Assuming this is their own private dwelling it needs no notification or Certification, they can do as they wish but I assume they have long been scared off.
Is it right that if it's your own dwelling you don't need to notify or certify at all? Is this for any work or just non-notifiable?
Never knew this if it's true.
That's what I deduce from the thread so far, PROVIDING they are competent, apply the regs and notify notifiable work
As an aside, have there been any convictions of homeowners who carried out electrical work in IE? Specifically I'm thinking of situations where no one was injured and the conviction was solely due to their not being registered to carry out the work in question.
Yes. Every year now there are a few. Interestingly it's the "not being registered" bit that causes the real problems. It does mean (unfortunately in my view) that a trained electrician cannot carry out electrical works in his own home which are deemed to be "restricted". Basically thats any works involving the CU
Oh yes, I always get a registered electrician in when I need some electrical work done in my own home.
So there will be plenty of people just doing work under the radar then. Same as here.
Work "under the radar" happens everywhere, all the time. But it's less likely to happen over here. You won, t find diyers on electrical forums in ROI asking how to connect up an extra socket etc. They would, nt be entertained. Even though they are entitled to do that work in their own home. But let's just say its not really encouraged. Or more accurately its probably frowned upon.
A few recent threads on this forum have concerned me, where it has been clear that the OP is well out of their depth.
Difficult to draw a line between giving basic information and leading people who clearly aren't competent to undertake the work in question.
That's it
My question was not about people misrepresenting themselves, but prosecution of homeowners who have undertaken works that should have been carried out by a registered electrician. Prosecutions involving work where no one came to harm as that would be comparable to the questions being answered about the UK.
I get that differences exist in legislation, but want to understand if differences exist where enforcement is concerned.
Fully agree, but there's nothing to suggest that the OP is incompetent in this thread.
On the other hand, the thread about transferring a socket from kitchen RFC to boiler spur ........
London
Adding sockets to a radial circuit in different directions
finlamit,
BiddeldyBwah,
