View the thread, titled "Live garden SWA wrapped in tape" which is posted in DIY Electrical Advice on Electricians Forums.
The image shows an SWA feed for a garden building which is not yet built. The feed is part of a new build house installation and the circuit is supplied via a hager RCBO and was energised when I found the cable, I've switched the breaker off. Is leaving a circuit in this condition compliant with the 18th Edition?
It's not compliant with the electricity at work Act 1989.the one that lands you in court /jail if something happens.the regs are guidance
My son bought a new build about two years ago. One switch of a 3G in the kitchen did nothing. Coil of 1.0mm2 T&E with exposed ends found on the top of a kitchen unit. Live when the mystery switch was on.
That was an extra cable for under unit lights lol .in truth some of the best sparkies I have ever worked with have made a mistake ,after all we are all human and for what ever reason sparkys undergo the same duress /stress as everyone else be it being put under impossible pressure by management or personal issues but what the op has posted seems an act of incompetence. But maybe his mate said he had placed it in a jb ,still wouldn't energize it though .
IMO the cable on top of the kitchen unit is more dangerous than the OP's. At least that one is taped up and in view, and would be approached with caution, as it seems the OP has. The kitchen unit one was not taped and just waiting for someone to reach onto the top of the unit.
It was RCD protected, I suppose, while the OP's may not be. No excuse for either.
How do you know it was energised? Just because the RCBO maybe ON, It may not have been as the cable may not have been connected within the CU. (See #2)
Returned to the property today and can confirm that the cable is connected to the shed RCBO. The developer's electrician is attending site this week. Many thanks for all the responses.
What if the RCBO had been locked off at the CU.
Not for me. Locking off is a temporary safety device whilst working on a circuit. I assume this is just a mistake. If this was intentional for future use to save pulling in a cable then like others of said you don't connect it!
This looks like an oversight unfortunately.
* I see this was for a future garden building so as others have said fine to have the cable installed to save that having to be done later but cable should NOT have been connected and energised.
There’s another circuit there for “charger” which is turned off.
Is that the same? A cable run in with nothing on the end of it, and just turned off?
Good old twin and earth sheath as grommet strip .tbh some of the grommet stripp you get with boards are to small and fiddely .there's a board that has or had smooth grommet stripp as apposed to the serated type that's far to small .prob hager.stand to be corrected on that just looks grey but neatly installed.looking again it's grommet stripp I'd say for sure.i need glasses I think
Reply to the thread, titled "Live garden SWA wrapped in tape" which is posted in DIY Electrical Advice on Electricians Forums.
