Guest viewing is limited
Hello guys! Just a quick question, is it good practice to place a socket on the same wall where the light switch is? Customer wanted socket on the same wall where light switch is. In my experience I have never seen sockets on the same wall as light switch. Please give me advice guys. Thank you.
It’s sometimes and advantage as you can get cables for both, down the same chase in the wall.
The one problem that can arise is 'safe zones'. If a single socket is placed directly under a light switch and all cables come from above, how do you get the cables to the socket past the switch with them remaining in an approved safe zone?
Pass them behind the back box.
Or
Use a deeper box and pass them straight through.
Along with already suggested.
You could surface mount them and use trunking or use quinetic for the switch.
London
Double socket on the same wall as light switch
Domestic Electrician Forum
Tags Tags
None
DJ12345,
7029 dave,
