Guest viewing limit reached
it is mate. i have seen a really small cam on the bay that you could pop onto the rods and view through a little lcd screen. i have a lcd fault finder for the cctv systems for a couple of years and a bullet type cam that has the same thread size as the cable rods. its great as i can get as many mtrs through voids as the cable i attatch to it. i would like a really narrow one for it though for narrow work
Bought one yesterday, along with a 1.5 metre USB extension cable.
Works well without the extension cable!
Can see this helping me with 2 jobs coming up.
Was toying with the idea of making one for the lap top with a USB cable, web cam and LED torch. Just rip out the web camera and put it on a long lead and use a LED with a variable resistor preferably powered from the USB. Then you could have the option of putting it on rods as you like and made very cheaply. Just a thought.
Got mine today wacked it under the sofa to see what I could find. Thought I found a head band and a big Choc gold coin but it was a little band and a pound coin. Everything looks so big.
works fine on the 3m extension.
I find the head has to be about a foot from the object to be life size on screen but the LED light isn't bright enough to reach that far in dark?
Looks like I might have to make my own when i wack it in a void i want to see along the beams etc as the one I just bought is no that long and with the light. HMMM
Ok to put in a hole to look in close proximity though.
Are the £200 + ones much better???
Maplin flexible usb snake scope on sale at maplin again £39.99
Australia
kung,
DurhamSparky,
