DurhamSparky
Wago Push Fit 24A 1/1.5/2.5/4mm
Lever Clamp ones = 32A 1/1.5/2.5/4mm
Large Red Pus Fit = 41A 4/6mm cable
I understood it to be inside the cu enclosure itself.would the wagos be in enclosure outside cu???
wagos on a dinrail????
If using butt connectors don't forget to heatshrink the joint.
Klippon.I think they are called clip on terminal connectors?
wagos every time....!! rated at 24A 32A and 41A depending on cable size and use!!
Klippon.
Just one of the many, many makers of DIN rail through-terminals. Others include Weidmuller (actually I think Klippon are Weidmuller now), ABB, Entrelec - all the usual suspects. Dunno about Wago, but most ranges will have poke'n'pray terminals if you're sold on the idea of bits of springy metal.
A box with a DIN rail and terminals would be my choice if you needed to extend all of them, e.g. moving the CU, but in the OP's case it sounds like only a few, so crimp. Wagos & choc-block would look naff waving around inside anyway.
As for colours - it's inside the CU, so you can use singles.
don't need heatshrink if inside CU.
anothe thought is could the new CU be located a few inches higher up so as to give extra cable length?
