Voltage drop and ZS - Some thoughts
Can you up the cable size to 4mm for the spur from the RFC? Assuming you're calculating it at 2.5mm ATM.
Err no. The customer has already had the builders install 2.5mm SWA under the new patio. Its been left for connection. I don't have too many worries about the VD or ZS but it just started me thinking about ZS and VD generally TBH with these scenarios.
Err no. The customer has already had the builders install 2.5mm SWA under the new patio. Its been left for connection. I don't have too many worries about the VD or ZS but it just started me thinking about ZS and VD TBH. I
Ah, OK. I thought you were having a VDrop issue because of the planned length of that part of the circuit.
Not really but this whole thing got me thinking. I am afraid I am a bit like that. Think of another scenario whilst dealing with one already. I suppose i just like to get my head around everything and this is the best place to do that!
I ahree with a few of theposts. I list the FCU (unless used for isolation purposes only, ie under a worktop) as a seperate circuit, and give it its own R1+R2, and Zs. This is an acceptable method of acheiving compliance with high Zs on a socket ect on a radial circuit for example.. Its also good for recording where reduced size cables are used from an FCU, say top feed lights ect.
With an FCU, that has an RCD protection at the origin, then 1667 will be the max Z, as that protectionwill operate before the 1363 fuse.
Look upon the supply to the FCU as a distribution circuit with protection from a B32A MCB and the final circuit from the FCU with protection from a BS1362 fuse.
You could add a second schedule of test results just for the final circuit from the FCU, treating the FCU as a distribution point.
Volt drop is measured from the origin of the installation.
Yes understood but a minor works would also meet the regs because it is not "a new circuit" in itself. Horses for courses I suppose! :smile:
pencilpusher,
malcolmsanford,
