has anyone pre ordered the new books yet and weres the cheapest place to get them was tempted to order mine on amazon £130 for the reqs,on site guide, gn3 your thoughts chaps
Discuss new reqs in the UK Electrical Forum area at ElectriciansForums.net
It is perfectly clear, and always has been. How could you install or verify an installation to a different Standard than that to which it has been designed?
Plastic CU, no code on the next EICR as complied at the time of installation.
Cables in escape routes, no code as complied at the time of installation.
The regulations are not retrospective.
I wouldn't put it as a C3 personally unless someone comes up with a good reason why it should be.
RCD protection only becomes necessary when you work on/alter the circuit.
I personally would C3 those items. Not the cables colours though unless a harmonization label was not installed.
They do not warrant a C3 code, item 1 in the below image explains all.
View attachment 27379View attachment 27379
Having one word wrong on a label or solid green sleeving are not in any way dangerous or able to give rise to danger.
But most old installations won't have a new colours label unless they contain both wiring colours.
Not aware that Network Rail require contractors to be registered with the NICEIC.
The fact that I'm not registered with the NICEIC, has not prevented me from working at various sites around London.
It appears that the quote that keeps getting copied and pasted is from one of the schemes, not from the IET. As such I would not place any value on the information.
Generally, I would apply a code C3, for instances where an installation complied at the time of it's design/construction, but does not comply with the current requirements.
For instance: cables concealed in walls without an acceptable method of additional protection, socket-outlets intended for general use by ordinary persons, circuits of a location containing a bath or shower, not provided with RCD protection, time delayed RCDs set to 5s, etc.
With instances where conductors have not been correctly identified, such as switch lines, where earth sleeving has been omitted or a lable indicating two colours of wiring are present, I would just rectify, and not bother applying a code.
I have never been registered with the NICEIC, and the last time I worked for Network Rail was at Paddington in January/February of this year.
Perhaps things have changed?
Is this a loaded question? Yes!!
What does the RISQS initials stand for??At risk of going off a bit. To gain RISQS (formally Link-Up) approval you will certainly require NICEIC membership. We have both.
They just love acronyms.
For the underground you need a LUCAS card, for Network Rail a PTS card.
Then there's the SPIC card, and a whole host of others
Reply to new reqs in the UK Electrical Forum area at ElectriciansForums.net
