Help!!! Can't turn electric off!!! | on ElectriciansForums
Guest viewing is limited
Discuss Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
Doug81
Nottingham
Hi, I'm currently in the process of changing all my switches and sockets and I'm coming across a few problems, like no earth wire for any of the light fittings. Similarly no earth for some of the upstairs plug sockets but the worst yet is the socket in the hallway (right by the fuse box). It has both new (blue,brown,yellow/green) and old (red,black) wires looped together -not a big issue I hear you say....well it is when the old wiring is live even when the fuse box is switched off!!! How do I go about making it safe???
[ElectriciansForums.net] Help!!! Can't turn electric off!!!
The red and black there is still live when the fuse board is turned off?
You have a serious problem.
How did you test that? Sore fingers?
Can you post a photo of your meter and fuseboard set up. There might be a clue as to what is wrong.
Can you safely protect those live cables from accidental touching?
How did a socket fit on that box with all that plaster taking up the top right corner?
Anyone in Nottingham up for a late night Saturday night callout?
Find out where it is fed from and turn it off
Turn off the whole house if you have to.
Don't let anyone near that.
Needs better picture than that Doug - we cant even see the labelling. Which mcb are you switching off when you are as none are off now. Puzzling!
Doug - Are you saying that the red stranded cables are live with the main switch on the far left turned off ? If so I suspect some dodgy goings on within the CU where some idiot may have bodged in a way of bypassing, god knows why though.
Or if you're saying no single MCB isolates the point it's probably cross-connected circuits across two devices, DIY is all well and good but I strongly recommend you get a decent electrician in - urgently. But why on earth did you remove the socket without isolating first ??!!
Reply to Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
Recommended Sponsor News
Hi everyone,
