Has this consumer unit been installed correctly? | on ElectriciansForums
Discuss Has this consumer unit been installed correctly? in the UK Electrical Forum area at ElectriciansForums.net
danny199
Essex
Hello,
Had a sparky install a new consumer unit, has it been done correctly. Bare in mind the chap cut corners on other bits of work he was contracted to do.
[ElectriciansForums.net] Has this consumer unit been installed correctly?
No, and originally he was going to come back and do some more stuff. I contacted him and he said he will sort certificate etc when he comes back. I don't think I want him back.
I didn't think that the copper wires should be showing like that.
How much will it cost to fix this to you think?
How much did you pay for this service? Quite often this is the result of the customer cutting costs. You get what you pay for.
That is no excuse you either carry out a professional job or you don't.
I could rip all that out and reinstall in a couple of hours. Then it requires a full test so 3 to 5 hours.
This cheapo customer paid £500 for a new consumer unit, 3 new plug sockets and moving two ceiling lights.
that is about the right sort of price to have the job done properly, not like that. might be worthwhile contacting Trading Standards.
also see if he's registered with niceic or one of the other schemes. if so, report him to them.
Probably about right, if the work is done properly and completed correctly.
You might expect certificates for the minor works carried out as well.
Was this artisan a member of any of the competent person schemes? He/she should be.
You should be able to find them here
Home - http://www.electricalcompetentperson.co.uk
Reply to Has this consumer unit been installed correctly? in the UK Electrical Forum area at ElectriciansForums.net
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
Recommended Sponsor News
Hi everyone,
