Wire Stripper Blade | on ElectriciansForums
Discuss Wire Stripper Blade in the Electrical Tools and Products area at ElectriciansForums.net
Strima
St Neots
Anyone know where I can get a replacement blade for my wire stripper? Not sure of the make as it's around ten years old and an eBay special but possibly a WilTec. All my searches are coming up blank.
OD of 38mm and ID of 16mm.
Plan B is make a mandrel up and put the blunt blade on the pillar drill to try and get a good edge back on it.
Thanks.
[ElectriciansForums.net] Wire Stripper Blade
Reply to Wire Stripper Blade in the Electrical Tools and Products area at ElectriciansForums.net
I felt a similar experience in my local store yesterday. I pressed the usual buttons, but then as the costa coffee machine started to fill the...
    • Dislike
    • Optimistic
5K
I honestly think that you need to troubleshoot the receptacles not working and is probably why you don’t have power outside.
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
6K
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
