Agreed... that's for Lithium Ion certainly, they don't like very high or very low charge for too long.
Interestly re:long term storage
The main considerations with the batteries seems to be to avoid complete discharge and excessive load, storage temp too.
Some of the new batteries (Makita)apparently won't operate at all if you try to do too much work with them, the electronics cuts out
The diss-charge cycle of LiIon batteries is quite level, but they do reach a cliff where they do not have enough power to keep the unit going, if you try to keep using the battery it will be irreversibly damaged.
Nice new Makita set sitting at my feet. Middle of the road stuff, but more than capable for the work most sparks would ever ask of them. Impact has a decent range of control that lets it perform tasks that earlier impacts would have been too aggressive for and both it and driver are smaller than my 12V Makita gear, although obviously a 5Ah battery changes that.
Just remembered the thread title, so link below as the set comes at a very respectable price.
I have the same set. (I paid more than that!)
So far I'm impressed. I got the the angle drill too.
Bought a 12V angle drill a while back. Torn between that and its big brother, but figured smaller form would be of more use than additional power - that and the fact that 12V was much less expensive ?
Do you find that you use it much ? I've been tempted to get one... but can't quite justify it.
Not used it so far, but I clearly remember every past occasion that I wished I'd owned one. Might never need it, but won't find myself needing it and not having it.
I do have an angle attachment (dewalt woodbutchery spec), but it's not ideal. Handy for driving, but not really robust enough for drilling with spade bits.
These guys were the cheapest I could find for 12V Makita, although not much use if you don't have batteries to suit:
I'm a labourer atm and it's only been the past 2 years I've started buying tools and I was immediately converted to dewalt I love a new dewalt tool
While slightly off topic but within the same field
The dewalt flexvolt dust extractor and wall chaser has anyone had any experience with them ? I can't find a decent review for beans I guess the obvious answe would be that it would be as powerful as corded equivalent
Bosch 18v 300nm , bought last year only used it once yet, good bit of kit.though
Are you using one of those big 54v drills ?
Was considering one for joists but i dunno
too heavy unless your name is Hulk. use a 110V. OK - tranny and leccy supply required, but your arms won't drop off after 10 holes, and youwon't be looking for that spare battery you left at home on charge.
Thats what I'm currently using hilti te5 110v
Best piece of electrical equipment I've ever owned
Was thinking cordless though for some jobs but
not interested if they're too heavy
The hilti seems to be about 5.5 kg
This would be for jobs where it's too much trouble setting up the corded,maybe 20 minutes drilling joists
Maybe something lighter like a 36v at about 3kg
Obviously bit quality is very important
For joist drilling, I was introduced to the Bosch self cut flat drill bits, used with an impact driver believe it or not. Incredibly quick and easy.
I have the 54 volt DeWalt SDS drill. It's very heavy and only comes out for the bigger jobs.
An impact driver!!!. Never heard of that before. Will certainly give it a go. Especially as, the impact driver, due to its compact size, gets in to places the usual battery drill won't go. Where would you recommend for the Bosch drill bits?
Muchas gracias. Out of curiosity, did you discover that the impact driver worked with these bits through experimenting or were you told about it?
Milwaukee wire stripper.The new "7 in 1" (the reason I came on here tonite before I got distracted with that nice impact driver tip) .I have had 2 already and lost both (rarely lose tools). But it became my favorite stripper for ease of use. The new "7 in 1" has added features and for 35 euro, I, m well pleased
I went for the 1/2 inch impact driver
Figured it would be better for heavy duty work
Trouble is when u want to use 1/4 inch stuff you're using adapters and afaik they don't last that well
That impact is a beast. If electrical work slows down you'll be ready to start up tyre fitting.
Ya ive only used it to remove a lawn mower blade
Nice to have it though
The adapters down to 1/4 inch seem to be a weak point
I would have hoped there would be a fixed type adapter that wasn't subject to wear and tear
Haven't used the adapter yet so maybe they'll last I dunno
Would be interested in trying it with the Bosch bits mentioned above
Funnily enough, I struggled to remove a mower blade last week and resented having to fire up the compressor for one simple task - 1/4" 18V impact wouldn't even look at it.
Not sure I'd want to use a 1/2" impact all the time, though as I find a 12V impact does 95% of what I need and weighs about the same as an average size potato.
Ya had the 12v Bosch impact for a long time , nice drill
Had a bad introduction to removing lawnmower blades
My supposedly knowledgeable friend said u remove them by turning clockwise
Turned out its anti-clockwise on mine
Great comparison ?
From now on when referring to an object's weight, I will relate it to number of average potatoes.
Blades are generally designed to self-tighten as they rotate. If in doubt, pull the plug lead and carefully peek underneath while giving it a slow pull - yeah, I know that isn't well worded ?
Great comparison ?
For small objects, it's easier to stick with one potato and roughly specify its size ?
Norwich
United Kingdom
Trainee Electrician
what are some tools that were worth the price tag?
Electrical Tools and Products
mrsparky,
Zimmerin,
