what are some tools that were worth the price tag?
My CK cable cutters 160mm and 210mm I usually have spare sets in the glovebox of the van as others seem to like them as much as I do or someone borrows them and uses them to cut nails ( only for copper cable )
Ideal for anything from terminating cat6 to 35mm tails I would recommend to any spark also a multitool I usually get the 20 pack of blades from amazon as it doesn't matter if you have expensive blades as when you hit a nail they get knackered just the same
Don't know if you would classify this as a tool, but a decent set of knee pads.
Was using 'foam' trouser knee pad inserts yesterday, and discovered me knees and location of inserts in the trousers don't line up well enough. - in a loft conversion crawl space.
So back to knee pads (and the problems they bring me) until I can find trousers that are compatible with my non-standard knees or knee pads without the before mentioned issues.
Cost next to nowt and not used for a good while, but yesterday, a quick search of the toolbox found me a little 3.5mm re threading tap driver to sort out a crossed back box screw fixing. Extremely useful.
on me they are more like shin pads , absolutely useless
i do have a set of gel knee pads but rarely use them
more often than not I just keep a bit of foam padding i Chuck on the floor to kneel on
I just fasten these round with velcro fastening. Not exactly modelling material but they do the job.
+million
Most guys only worry about their knackered knees when its too late. Some of the best advice you can give, take care of yourself, poxy job ain't worth suffering for!
The inbuilt knee pads are ace because you never don't have them on, for those "oh it'll only take a minute not worth getting the pad out the van" jobs that you're still struggling half an hour later! I found wearing knee pad trousers that come with a short leg option puts the knee pad in the right spot!
+million
Hence why I'm on the waiting list for new set of knees :(
