Extending cables for a new board change | on ElectriciansForums
Discuss Extending cables for a new board change in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Newcastle
Hi all, looking for some advice with regards to extending cables for a consumer unit change. The old board is a mess inside with cables being cut short etc. What's your go to method for extending. When I've only had to extend a couple I've used the Ideal inline splice connectors, but this is gonna need nearly all of them extending. Din rail connectors in an enclosure seems popular. Does anyone have any pics of their work doing this? Thanks in advance!
With regards to RFC would you put both legs into one connector or one per connector?
To make it as easy as possible for a future tester trying to do R1+R2 I'd do two connectors, so they don't have to disturb the enclosure with the extensions.
here's one i did a few years ago:
  • [ElectriciansForums.net] Extending cables for a new board change
Maybe have a look at these guys.
Costs a wee bit more than making it up yourself but if you dont have all the connectors i might save buying them in bulk and not using them.
Reply to Extending cables for a new board change in the UK Electrical Forum area at ElectriciansForums.net
Like the idea of hinging the ply. It was in the back of my mind that if there is a fault back there it would be a nightmare. I was planning to...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
Rough is being exceedingly generous. Never ceases to amaze me what people will walk away from. That could have been so much better with a little...
6K
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
