Extending cables for a new board change | on ElectriciansForums
Discuss Extending cables for a new board change in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Newcastle
Hi all, looking for some advice with regards to extending cables for a consumer unit change. The old board is a mess inside with cables being cut short etc. What's your go to method for extending. When I've only had to extend a couple I've used the Ideal inline splice connectors, but this is gonna need nearly all of them extending. Din rail connectors in an enclosure seems popular. Does anyone have any pics of their work doing this? Thanks in advance!
With regards to RFC would you put both legs into one connector or one per connector?
To make it as easy as possible for a future tester trying to do R1+R2 I'd do two connectors, so they don't have to disturb the enclosure with the extensions.
here's one i did a few years ago:
  • [ElectriciansForums.net] Extending cables for a new board change
Maybe have a look at these guys.
Costs a wee bit more than making it up yourself but if you dont have all the connectors i might save buying them in bulk and not using them.
That's very impressive work
Do you have a technique or particular method for bending the cables and checking the radius of the bend
eyes and fingers.
Reply to Extending cables for a new board change in the UK Electrical Forum area at ElectriciansForums.net
Have you looked at the Wiska Wago relocation product. Different sizes available. Saves having to reinvent the wheel. CLICK ME
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
