Vice have been taken over by Irwin ; another quality supplier. Mine are about 35 years old and still going strong.Never entered my mind - another tool for the list, either now or in the near future.
Discuss Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
I got mine about 6 months ago. "TIS LIGHTAD" on ebay - they are currently £50 delivered. Doesn't help you with an amazon voucher of course!Great shout!
Looked at them many times, but never pulled the trigger. Didn't realise TIS made a version as I'd only seen Kewtech and Socket & See.
Just noticed Amzon themselves are £10 more expensive than other sellers and the voucher can only be used on purchases from them ?
Knipex ergo strip, Klien conduit level if you do a lot of pipe. Small stabila level that fits inside patress', Bosch multimaterial drill bit set, keyring magnetiser, Superrod double ended supergrip (crskd-1114)
They seem to have slightly longer shafts than the Kewtech ones my mate has which helps. I have to say they are getting used an awful lot. One handed R1+R2 at light fittings is nice.
A decent set of hole saws or wood bits
Dilog, beha amprove, Martindale and a few others also do themErgo strip I've looked at many time, but could never quite decide if it would ever get enough use.
Mini level I have the Stanley 042130 - bit larger than Stabila mini, but liked that it had horizontal & vertical. Slightly wider than 1G pattress.
Drill bits coming out of my ears.
Small magnetiser is very hady - provided it's not at the bottom of a box.
Have small, cheap rods & CK Mighty set, but also recently picked up Super Rod CRSK12 (comes with 2 sizes of supergrip) as Amazon were running a bargain price.
Can't believe I never saw that TIS set before and price is much better than either of the other options.
Literally have thousands of Metabo holesaws, supplemented with a few cheap Erbrauer for larger sizes.
Spade bits are a subject I've never properly addressed. Currently using a cheap Dewalt set, with several brands added as replacements. Bosch speed cut seems to be highly rated, but I generally have 12v tools to hand and always felt that speed cut would be a bit aggressive for them.
Not sure if I've found anything suitable to buy from Amazon on this occasion (possibly Knipex installation pliers...), but appreciate everyone's thoughts and can now add a few more tools to that ever expanding and contracting list ?
I've had a couple of the Kewtech Lightmate kits over the years, but (a) found them a bit large to fit in some light fittings with small shades, and (b) prone to damage or going intermittent esp. if dropped now and again. Then I found this Amprobe kit, where the adapters are so much slimmer and fit where the Kewtech ones don't. A bit pricy, but I wouldn't go back to Kewtech ones now:Do you have the Kewtech Lightmate kit? (I've got the cheaper TIS one but Amazon don't seem to do that!)
Striped screw extractor set, for when screw heads are stripped by Joe public using the wrong driver or Cowboy spark using an impact on EVERYTHING
Reply to Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
