Suggestions for useful tools... | Page 2 | on ElectriciansForums
Discuss Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
Great shout!
Looked at them many times, but never pulled the trigger. Didn't realise TIS made a version as I'd only seen Kewtech and Socket & See.
Just noticed Amzon themselves are ÂŁ10 more expensive than other sellers and the voucher can only be used on purchases from them ?
I got mine about 6 months ago. "TIS LIGHTAD" on ebay - they are currently ÂŁ50 delivered. Doesn't help you with an amazon voucher of course!
They seem to have slightly longer shafts than the Kewtech ones my mate has which helps. I have to say they are getting used an awful lot. One handed R1+R2 at light fittings is nice.
Knipex ergo strip, Klien conduit level if you do a lot of pipe. Small stabila level that fits inside patress', Bosch multimaterial drill bit set, keyring magnetiser, Superrod double ended supergrip (crskd-1114)
Ergo strip I've looked at many time, but could never quite decide if it would ever get enough use.
Mini level I have the Stanley 042130 - bit larger than Stabila mini, but liked that it had horizontal & vertical. Slightly wider than 1G pattress.
Drill bits coming out of my ears.
Small magnetiser is very hady - provided it's not at the bottom of a box.
Have small, cheap rods & CK Mighty set, but also recently picked up Super Rod CRSK12 (comes with 2 sizes of supergrip) as Amazon were running a bargain price.
Can't believe I never saw that TIS set before and price is much better than either of the other options.
A decent set of hole saws or wood bits
Literally have thousands of Metabo holesaws, supplemented with a few cheap Erbrauer for larger sizes.
Spade bits are a subject I've never properly addressed. Currently using a cheap Dewalt set, with several brands added as replacements. Bosch speed cut seems to be highly rated, but I generally have 12v tools to hand and always felt that speed cut would be a bit aggressive for them.
Not sure if I've found anything suitable to buy from Amazon on this occasion (possibly Knipex installation pliers...), but appreciate everyone's thoughts and can now add a few more tools to that ever expanding and contracting list ?
Dilog, beha amprove, Martindale and a few others also do them
The Knipex is great for flex, does a very nice job without nicking any of the cores...
Don't find the other bits that useful though - For stripping end of cores where limited space I find the Jokari all rounder pretty useful though and nice and cheap too.
I struggle to use it to strip Twin and Earth though, I think you need to get the technique just right...
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Never seen light test adaptors from Martindale or Di-Log and can't find htem in current ranges. Beha-Amprobe make top notch gear, but a little spendy for these adaptors. TIS looks like the best option (for me), but that'll be for another day.
Figured it'll be something my miserly mindset considers to be extravagant. Ergostrip always looked interesting, but have a Weicon stripper that does the same job, albeit less quickly. Knipex stepcut looks interesting, but have a couple of pairs of croppers that'll do for some time and, besides, Amazon seem to have trust issues about supplying them to people in NI!
Don't need them but, what the heck, I'll go with the installation pliers suggested by @Pete999 - Amazon price is as good as any for the non-sprung version (don't like the idea of spring and lock) and that ÂŁ10 off helps me justify this indefensible expenditure ?
Appreciate all the suggestions and, if anyone happens to have more ideas, feel free to contribute as I'm always receptive to ideas for future tool purchases.
knipex crimper for insulated crimps . the jaws are narrower than other makes so you can safely crimp 1 end without partly crimping the other end, and the pressure is adjustable,
Do you have the Kewtech Lightmate kit? (I've got the cheaper TIS one but Amazon don't seem to do that!)
I've had a couple of the Kewtech Lightmate kits over the years, but (a) found them a bit large to fit in some light fittings with small shades, and (b) prone to damage or going intermittent esp. if dropped now and again. Then I found this Amprobe kit, where the adapters are so much slimmer and fit where the Kewtech ones don't. A bit pricy, but I wouldn't go back to Kewtech ones now:
I paid just under ÂŁ67 inc. VAT online about a year ago, but you can easily pay over ÂŁ100 if you don't shop carefully. They seem quite rugged but I've not tried dropping any of them, the price makes me a bit more careful!
Striped screw extractor set, for when screw heads are stripped by Joe public using the wrong driver or Cowboy spark using an impact on EVERYTHING
Had a few sets over the years, but was never impressed by any of them. I suspect paying a little more might go a long way with screw extractors.
10mm & 12mm plug cutters, for chipboard flooring.
Get around the nails and resecure with screws
[ElectriciansForums.net] Suggestions for useful tools...
Reply to Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
On the 4th day God created this sun:
T
TTA Supports Lighthouse Charity and Appoints Mental Health Ambassador - From TTA TTA Supports Lighthouse Charity and Appoints Mental Health...
The Tile Association
T
