Suggestions for useful tools... | Page 3 | on ElectriciansForums
Discuss Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
There are a couple of other interesting tools for cutting access holes in chipboard flooring.
4" or 5" hole with rebate for plug or plate.
Superrod Cavity Master?
Not sure of names but, of the two that come to mind, one provides a steel plate (presumably requires a little sealant or adhesive) and the other a plastic plug.
I like the idea of cutting around screws, but you still have tongue to cut. I guess access holes are handy when you know where to cut and lifting sections the better option when you don't.
that weetabix flooring is the spawn of the devil, with water pipes tight up against the underside. if i need some cutting out, i get the customer to do it.
you get a little camera that if you drill a 16mm hole you can poke the camera down to check for pipes before ripping through the floors with a circular saw
yes you might hit a pipe when drilling the small hole but it’s less risky than going at it with a circular saw
One of those "ferret" cameras is also on my wish list!
Quite a good way if you need a big access hole , the black plastic spinning thing gives you the correct depth
Was half minded to add to the tool collection tonight, with suggestions in mind from this and other threads. Glad I did as Amazon had Super Rod's Cavity Master kit in a warehouse deal for just over ÂŁ24. Added a spare Wera #2 Robertson blade & Armeg roofing bolt driver and Amazon gave another ÂŁ5 off if I used click & collect. ÂŁ35 & change for the lot seemed like a bargain and I take back (some of) the stuff I've said about them.
Recently the "Badaptor" caught my eye. Have, nt bought one yet but almost certainly will. Being able to interchange 18 volt batteries from different makes sounds like a great idea
Seems to be mainly intended for Ryobi tools, but you need a different adaptor for each battery manufacturer at ÂŁ20 a piece.
They do have an adaptor that mates Milwaukee & Dewalt batteries to Makita tools for ÂŁ35.
A pro pac and a snap on ratchet screwdriver are both on my to buy list if i come across someone local offering them up for sale
Reply to Suggestions for useful tools... in the Electrical Tools and Products area at ElectriciansForums.net
On the 4th day God created this sun:
T
TTA Supports Lighthouse Charity and Appoints Mental Health Ambassador - From TTA TTA Supports Lighthouse Charity and Appoints Mental Health...
The Tile Association
T
