AT28C16 EEPROM learning experiments | Page 2 | on ElectriciansForums
Discuss AT28C16 EEPROM learning experiments in the UK Electrical Forum area at ElectriciansForums.net
_q12x_
New York
Thanks to mister @marconi , I received his chip AT28C16 gift from England !
I will start to make the 5x7 led matrix project that you did.
I will make it alone as much as I can (as usual). And I will ask you for clarifications on the way.
Home - BBC News - https://www.bbc.co.uk/news
As friends of the United Kingdom I thought you and Romania might like to look at some of the television coverage of the funeral of our late dear Queen Elizabeth. Most of today many (millions!) have been watching the television and listening to the commentaries, music and prayers - very moving and a glorious way to mark Her Majesty's passing. I hope you gain a sense of how loved and admired she was by ' the great and the low'
  • I was having today a strange feeling about UK queen funeral... without watching any news, because I was working all day long like a slave. I had a brief feeling at some point. Strange things are transmitted, even feelings.
  • Indeed, Romania is transmitting to England it's sincere condolence and we are sharing a tear along with you with a piece of broken hearth as well.
1. Connect a 0.01uF capacitor between 5 and 1.
2. Connect a 0.1uF in parallel with a 1uF electrolytic between 8 and 1.
Is the pushbutton 'normally closed' as you have drawn?
The button is staying in a open position and is closed/contacting when is pressed.
This is the type of button I am using:
[ElectriciansForums.net] AT28C16 EEPROM learning experiments
Im sorry Im not that bright as you may think I am, what 5 and 1? and what 8 and 1 are you referring to?
Ive tested separately the 7493 and it turns out is a good chip, undamaged !!! GOOD !
Then it remains theNAND and theAND chips to be verified. And if they are bad, I will have to build a gate from discrete components.
Im discussing this problem on another forum in parallel with this one.
I just copied what was there into here.
So the big problem I am facing today is to make this 7493 IC count to 7....
In the proteus simulator, is working fine, but in reality, it stops to 4, doesnt matter the wiring I put on it !!!
I tried separately this circuit and now is counting up to 16, for 2IC's 7493 - the one I was using all the time and a brand new one.
So this is telling me the 7493 is a good chip, undamaged !!! GOOD !
Then, I switched to another NAND gate on the chip. Also I switched to another AND gate on the chip. You know, to try other gates from the 4 they have, in the idea maybe 1 gate is busted but the others are good.
I got the same result. It is counting and stops at 4.
It is counting to 3 actually (lit 2 leds), but when is trying to count to 4, is resetting. Like the wiring is connected for a 4 counts.... like this:
I became suspicious on my AND IC and I read carefully on it again, and it says CD4081BE. So it appears to be the right chip for an AND gate... But it behaves like a NOT gate...
It might be what you just said mister @dl324, being CMOS, easily damaged by ESD, either by me or from the guy I take it from, or board I scrap it.
I believe it is time to make a NEW and Glorious AND gate from discrete components. I only need 1 so its not a big deal.
I never built any logic gate before. This is my first time. And my first instinct is to make if from diodes. Like in this example:
I assume that RL is a 10k?
I am also thinking to test both IC's -theNAND and theAND- and see if they are doing what they should...before building a discrete gate.
And I just tested theAND gate. It does what it say it does. When A and B are to gnd, or one is on (+) and the other is on (-), the J output stays LOW. But when both A and B are to High, the output J gets High.
BUT... with an interesting side effect. When 1 or both A and B inputs are not connected to (+) or (-), when they are floating, the output J gets High....
Ta-ta-tam !!! This may be the reason mister @dl324 was saying these chips categories dont match eachother? the TTL and CMOS? May be.
One answer is certain. If one of the inputs (or both) gets in a tristate mode (not - not +) then it's output is High, and is certainly confusing/overriding the counter.
So, I solved this --floating problem-- by inserting 2x10k on each input pin (on A and B) and indeed solved it. I only had to put 1x10k on a single pin and the output wasnt High when floating. Also, it didnt affected the normal operation at all. Only when both A and B were High the output got High. The rest of the cases, is staying Low. Which is good.
I immediately inserted into my counter circuit. Absolutly no effect, it is still counting to 4. Incredible !!!
I also put 10k on the NAND inputs, and outputs, everywhere. No effect on the counting at all, still counting to 4. Again, incredible !
What a puzzle to descifre!
To count from 0000 up to and including 7 ie 0111 in binary the reset to state 0 ie 0000 takes place on the 8th state ie 1000. Thus connect both reset pins to Qd.
  • [ElectriciansForums.net] AT28C16 EEPROM learning experiments
Ok, at the moment it is counting to 8. If you number from 0 to 7 you will get 8 pulses.
I need 7 counts, that means from 0 to 6. Right now, when is reaching 6, leds stay open but in the moment is counting 1 more up, to reach 7, to light all those 3 leds, it should imediately reset to 0. As usually does when is reaching a certain programmed value. But in my case it is litting all 3 leds on 7, sign that is actually counting to 8. So right now is still not good.
Unless it is some trick that you know and I dont?
For seven counts from state 0 to state 6 the reset to state 0 happens when the output state is 0111 ie on the seventh state.
Thus one must AND the outputs Qc, Qb and Qa to produce a reset pulse when they are logic 1. The reset pulse goes to both R1 and R2.
To avoid timing errors we should AND these three Qs in one gate. Do you have any three input ANDs, NANDs, ORs or NORs?
Dispense with the first ff stage ie clk a and Qa. Feed clock into clk b. Use the three ffs of second stage ie Qb, Qc and Qd only as the 1, 2 and 4 outputs respectively. Connect reset R1 and R2 together and to a logic circuit which provides a logic 1 when b, c and d are all logic 1.
I thought of that as well
For theAND gate Im using CD4081BE
and for theNAND gate 74LS00
I just lift up from my chair and checked the IC's on the breadboard. Im not telling you from memory, but from seeing.
or.....maybe the counter 7493 is not liking theAND gate CD4081BE ? An incompatibility?
And somehow switching at #4 because some internal errors between these 2 IC's?
Yah... it might be it... its one plausible explanation.
7u
I have to take my wife out but quickly the 4000 series output can only drive one 74LS series input. Try disconnecting the nand so the and only drives the reset input.
Have you tried this? That cmos AND should be able to drive one 74LS input in your case R1. The Qd connects to R2.
With the 93 at 0000 please measure the voltage of the output of the AND with reference to OV. It has to be less than 0.8V to be interpreted as a logic 0 by the 93. Do this with nand connected to the and output and then with nand disconnected from the and output.
if R1 is not being held at a voltage which 93 interprets as a 0, but rather as a 1 then all it takes to reset 93 is for R2 to become logic 1 which happens when qd becomes 1 at a count of 0100. Thus it resets to 0000.
For 74LS a logic 1 input is a voltage greater than 2V.
A new AND Gate , a new breakthrough ! But still not good.
Now Im trully desperate. I have NO idea what to do next.
Please see this small video here and tell me what you think.
You could do those voltage measurements I suggested recently. You could do the trial without the NAND in circuit.
Please measure the voltage of your power supply using a voltmeter and tell me what it is. Not the meter on the power supply.
The voltage of the output of the AND when 93 is at 0b0000 (0decinal) is 0.025V = 25mV
The voltage of the output of the AND when 93 is at 0b0011 (3decinal) is 5V
so when is reaching 4decimal , is already High?
Reply to AT28C16 EEPROM learning experiments in the UK Electrical Forum area at ElectriciansForums.net
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Amazing, very informative and brilliant system.
