Dodgy trade pictures for your amusement! - 1 Million Views! | Page 456 | on ElectriciansForums
Darkwood
Had an identical one on my 180A oil filled arc welder for about 30 years, plugged into a MK surface socket from the same era. Never showed the slightest sign of heat damage.
The one with a bolt replacing the fuse?
Bolts are made of steel, so that would have been a right bodge.
13A fuse with a bit of 30A fusewire soldered across it is much more sophisticated
Use the neutral pin out of another one, jobs a good un.
