Dodgy trade pictures for your amusement! - 1 Million Views! | Page 472 | on ElectriciansForums
Darkwood
Had a regular customer in a semi detached house, with a simple pyramid shaped roof covering both properties.
About 15 minutes after turning the loft light on, there would be two or three hornets buzzing around it, just two or three, never any more. Looked into every corner many times, and never saw any signs of a nest, or any other clue as to where they were coming from.
Was like this, every time, over a period of about 20 years.
I worked in a local village hall a couple years ago.... stuck my head up the attic hatch, pulling cables from the higher roofspace above the actual hall.... working away quite happily.... then i turned around.....
Bloody wasp nest, 2 foot in diameter!.... 2 FOOT!!!!
F**king hate wasps..... nasty little beasties.
Not too keen on them myself.
They set up camp inside the solid stone wall of my living room a few years ago, getting in and out through failed pointing in multiple places. A complete can of expanding foam into the wall dealt with them.
They weren't too happy about that and went on the attack, but they don't fly too well with a lump of rapidly expanding and hardening foam on their backs.
i think i maybe did!
I keep a spray can of wasp killer in my van for such eventualities
Washing up liquid kills them on contact. Spray bottle with a fairly strong solution of it will sort them in no time, without lasting impact on your lungs or expanding foam stuck to everything.
I didn't believe this would work until they decided to begin nesting in our bin - huge swarm neutralised in a couple of minutes.
Had to deal with these bees, at least it was outside, but had to open the window to unlatch the shutters, I found that the Hornets tend to leave you alone if you don't wave your arms around, they where quite happy buzzing around me whilst I was re-pointing the chimney.
Scairy Liquid......to the wasps, then?
Slightly optimistic earthing. 16mm from each of the two DBs, to a single strand of something that would definitely have been measured in fractions of an inch when it was installed many decades ago (and not for the purpose of earthing the installation!)
