View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Cut a big hole in the ceiling which is hidden by the fitting and put a couple of battens up there to screw into.
Patch up the hole to stop the rubbish falling through, but it doesn't need to be neat as it is hidden by the fitting.
Lovely days work sorting all that lot out
Assuming its not Eco7, you could fit a lovely Rcbo board an replace those 3 x 3036 boards and do away with all those tails splitters
Yes thats the intention but there are lots of other problems that need looking at as there are sub main feeds to a kitchen and stables Pme earthing, tails from cut out are around 15mtrs running through fabric, etc etc
The E7 is still there, but not used any more.
It has an astonish "this has grown and mutated for 50 years" look to it, with never a "lets do it properly" stage!
I guess even if they had/wanted that then @Dustydazzler 's suggestion could work with a dual-row RCBO board if needed?
Spot on, did over the last 45yrs or so.
Not due to be done yet but joined to a cottage which I have to try to sort out.
If you do this job then a series of time-lapse images from start to finish would be nice to watch. And a few remarks and comments by each perhaps in way of a master-class.
It's not due to be done for a while, but I will do as you suggest, there are more than a few problems that need to be addressed first.
post #7,000 is the adjoining cottage, which feeds a sub main to another cottage.
I don't know about Master class though :)
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
