View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
5 amp lighting fuse had four wires.
1 - every light in house (IR of zero)
2 - not identified (IR of >299M)
3 - smokes (IR of >299M)
4 - outside light.
Every pendant had a hidden junction box above it so I was looking for an easy place to break the circuit.
First floor board I pull up:
Oh great.. every fitting probably like this, and separating them didn't improve IR.
Obviously I wasn't going to leave it like that, so I did my own dodgy contribution as I'd run out of cable ties. I felt it was in keeping with the rest of the house.
Taking down a temporary power feed this morning. had been working perfectly well, last used Thursday I think. Decided to see how dry the Wago box was, lost quite a bit of water before getting this far:
Yup, the lower half (as it sat dangling from the 3 core) was ice and the rest water. I am surprised it didn't trip the RCD, maybe the water was relatively pure?
Presumably wicked down along the earth wire.
Taking down a temporary power feed this morning. had been working perfectly well, last used Thursday I think. Decided to see how dry the Wago box was, lost quite a bit of water before getting this far.
Can't remember if I posted this, but you wouldn't have had the issue had you followed this exemplarily method of working:
I dont think the membrane seal is intended to seal when you poke a hole in it like that.
a suitable compression gland would have probably done much better.
p.s. the glands need to be done up correctly with a spanner, hand tight will not provide a good seal.
In fairness I thought that ice was what was left of the gel😂😂😂
It looks like a Wiska Box rather than a Wago Box though, and I've never seen water in (or ice) in one of those before, but never seen one done quite like that either.
As above, if it was buzzzzzzzing, i would Wasp the F out of there.
some interesting collection of wire types and not quite perfect terminations.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
