View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Wow, you'd expect them to be sorting that out for free as it's their equipment and well past its sell by date !
They'd change the head for free if they'd installed the earth - they clearly hadn't - or someone needed to pull the fuse - like a meter change. But the fee is for providing a PME earth, and fitting an isolator. The head - and the associated work, like digging a hole in the client's front garden - is effectively free
Not a bad deal in the grand scheme of things
Today's fun and games. A few interesting period features and no shortage of eyebrow raisers.
My immediate suspicion about Neutral no 1 was correct:
The lighting in double insulated 1-core had more recent CPC's added, and upstairs just about checked out.
Downstairs didn't - only the hall and lobby was giving an R1+R2. All other downstairs lighting had such a large induced voltage (27v) on the separate CPC that the the tester refused to do a continuity test, so there's a missing or broken link. This was also leading to interesting flashing effects of LED bulbs when turned off, lasting minutes in some cases.
What's the white box before the meter?
Is it badly fitted over the top of an older recessed board?
This is one of several properties on the same private estate, There is a substation on site and upstream distribution boards.
It's just an enclosure where the distribution circuit's SWA is badly terminated and the cores pass right through to the meter!
It looks to me like either the owner or Mr do it all has done that work.
Yes. It looks like they put in a new kitchen ring when they changed the board, as all other circuits are stranded zinc plated copper.
"Mr do it all" who was employed by the owner has just retired after many years tinkering with this installation. After a quick look around I've politely declined to touch anything until the relevant part of the installation has had an 100% EICR. This one was consumer unit 3 out of 12 that are for living accommodation (which we agreed to do first). There are a further 3 identical properties to look forward to!
That's strange because for something so non-compliant it's actually pretty neatly done - the 90 degree bend on the T&E where it goes vertical is very nicely done for example.
I've since wondered whether the switchgear changed and the old arrangement had provision for the lighting circuit.
I need to go back here to take lots of photo's, there's a large transformer / rectifier for a pipe organ below the switched fuse. Behind the photo is the bell rope and a vintage (long broken) electronic bell so someone the other end of the church could signal when to start and stop ringing.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
