Dodgy trade pictures for your amusement! - 1 Million Views! | Page 518 | on ElectriciansForums
Darkwood
^^^^^ so not only has a neat installation Benn made rough, but was that RCD needed for fault protection? Looks like a TT system to me!
Sy
Oops just looked again and PME I take it from the second Henley/ service blocks.
You were right the first time it's TT, the meter man removed the Rcd being used for fault protection.
Well he needed somewhere to stick the warning labels....two colours of cable, which ain't needed. Then, a warning not to store combustible materials close to the equipment... at high level, above a door seems weird.
Is it common for meter fitters to remove components which fall outside the scope of their work?
Had one yesterday where I had fitted new cu and isolator a few months ago.
Meter man came to put in a smart meter and replaced the new Wylex rec2 telling the customer that the regs have changed so needs replacing with an eon labeled one.
Needless to say he took the wylex one with him for I assume safe disposal on eBay 🙄
At least he left a new one, regardless of whether it was through idiocy or self gain.
